Need a System32 file!
Davi
All of a sudden, my SysClass.dll and KBDBR.dll appeared 0kb-sized...
I managed to download kbdbr.dll but can't find SysClass.dll anywhere! Could anyone please send me a copy through Rapidshare?
I'm using Vista Ultimate PT-BR, but I think any version should do it...
Thanks!
I am no expert, but I googled your .dll file and one of the items was this....CHECK HERE
Please be certain that you are happy with the result before acting upon it.
In fact it may be worth waiting for one of the other more enlightened members to take a look first. :)
Perhaps you would also like to take a look at all of the results of my Google...........
GOOGLE RESULTS
I have to admit that I know nothing about Vista, but in all previous Windows versions there was a System File Checker program that can search for missing or corrupt system files and replace them. Do the following
Start -> run -> type
cmd
. Once the command prompt is open, type
sfc /?
- this will show you the possible parameters of the system file checker. In previous Windows versions it was
sfc /scannow
to run the checker.
Pat the sfc on my computer ran and found heaps (I think) of errors. Then it told me to restart my PC. Did so, still have hal.dl error at startup!
Davi, here is the file (sysclass): http://www.mediafire.com/?eddz4d4t6nm
And I thought I should also give you the other file (KBDBR): http://www.mediafire.com/?bymgde2i3ny
They are both from Windows Vista Ultimate. (Latest version, retail, with latest updates!) :P
Hope this helps,
Panarchy
