Spaz Posted June 26, 2007 Report Share Posted June 26, 2007 Not sure if this has been covered, but it would help for future searches for those that are interested in displaying IE7 on the desktop without creating a shortcut.1. Click Start, Run.2. Type "regedit.exe" (Without quotes).3. Navigate to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel 4. In the right hand pane, double-click {871C5380-42A0-1069-A2EA-08002B30309D} key.5. Enter dword value as 0 to enable the Internet Explorer icon on the Desktop. Quote Link to comment Share on other sites More sharing options...
crashoverride Posted August 12, 2007 Report Share Posted August 12, 2007 woow thats alsome thanks for the heads up. Quote Link to comment Share on other sites More sharing options...
mcb2001 Posted August 13, 2007 Report Share Posted August 13, 2007 Not sure if this has been covered, but it would help for future searches for those that are interested in displaying IE7 on the desktop without creating a shortcut.1. Click Start, Run.2. Type "regedit.exe" (Without quotes).3. Navigate to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel 4. In the right hand pane, double-click {871C5380-42A0-1069-A2EA-08002B30309D} key.5. Enter dword value as 0 to enable the Internet Explorer icon on the Desktop.How about:Right click your desktopGo to settingsClick the tap "desktop settings"click the button "customize your desktop"click the checkbox "show internet explorer on the desktop"press OKpress OK:-) Quote Link to comment Share on other sites More sharing options...
djohn Posted August 13, 2007 Report Share Posted August 13, 2007 Yep, your quick step is fine for XP, its the way I do it and use the same routine for a couple of other Icons as well but does it work for other versions of windows? :) Quote Link to comment Share on other sites More sharing options...
AlanHo Posted August 13, 2007 Report Share Posted August 13, 2007 How about:Right click your desktopGo to settingsClick the tap "desktop settings"click the button "customize your desktop"click the checkbox "show internet explorer on the desktop"press OKpress OK:-)This topic was posted in the Vista section - but your method will not work with Vista. As DJohn surmised - it appears to be restricted to XP Quote Link to comment Share on other sites More sharing options...
Staff Posted August 13, 2007 Report Share Posted August 13, 2007 What a mess! Something that worked in XP does not work in Vista, not new.Fortunately I use Firefox.Staff. Quote Link to comment Share on other sites More sharing options...
Spaz Posted August 22, 2007 Author Report Share Posted August 22, 2007 How about:Right click your desktopGo to settingsClick the tap "desktop settings"click the button "customize your desktop"click the checkbox "show internet explorer on the desktop"press OKpress OK:-)Give it a shot, show me screen caps that Windows Vista providing that feature. I've only seen Window XP machines capable of that. Quote Link to comment Share on other sites More sharing options...
mcb2001 Posted August 22, 2007 Report Share Posted August 22, 2007 guys, i just reply to alot of posts, as you might have seen...If i dont always see that its the vista or xp section being used, is a human fault...But if you go to:control panelpersonal settingsand then look at the right side, there will be a task called something like "change desktop icons".In there isn't ANY IE7, and thats is because the EU made a lawsuit against Microsoft - and won.And a part of that lawsuit was that IE shouldn't be a standard part of the OS, but a stand-alone program.This applies for XP mediacenter as well as Vista.So once again, sry about the small mistake, and good finding... Quote Link to comment Share on other sites More sharing options...
Spaz Posted August 22, 2007 Author Report Share Posted August 22, 2007 lol I wasnt being mean, dont be sorry either. Good info you got there, but I would recommend reading the material before posting. It can help prevent confusion or madness even :)I know it becomes a habit of posting to threads, I do it all the time (automotive forums rx7club.com/evolutionm.net) But yea, thanks and have a good one :D Quote Link to comment Share on other sites More sharing options...
