poundhound Posted July 3, 2007 Report Share Posted July 3, 2007 Hello all,I have recently updated my mothers pc to service pack 2. It took a while to load so left it with her to close down so am not sure of her procedure.The problem is that after the sign-on the pc loads the settings but does nothing else, just a picture of the desktop background.Its as if the startup has lost the comands needed to start explorer and therefore show the bottom start bar and any desktop icons.#It is possible to start some programs using ctrl alt delete to get task manager and start new task but I have no idea how I can get it to start explorer (or even for that matter if it will!)Has anyone got any fixing suggestions?I know the xp software is already installed on the hard drive (so no instal disk) and am completely unsure how I can even format the hard drive and re-load the original software (even if it means losing all other data - its worth it to get the pc back!). Can this be done at the bios? many thanksken Quote Link to comment Share on other sites More sharing options...
Boris Posted July 3, 2007 Report Share Posted July 3, 2007 Have you tried a System Restore back to before you installed SP2 ? Quote Link to comment Share on other sites More sharing options...
poundhound Posted July 3, 2007 Author Report Share Posted July 3, 2007 Have you tried a System Restore back to before you installed SP2 ?Thanks Boris,Can I do a system restore without accessing windows? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted July 3, 2007 Report Share Posted July 3, 2007 http://www.windowsforum.org/forums/index.php?showtopic=15213 is similar to system restore, and should help you. Quote Link to comment Share on other sites More sharing options...
Boris Posted July 3, 2007 Report Share Posted July 3, 2007 Thanks Boris,Can I do a system restore without accessing windows?Hold the F8 key down as its booting to give you access to starting in Safe ModeChoose Safe Mode from the options displayed - and you should get a System Restore option offered there Quote Link to comment Share on other sites More sharing options...
poundhound Posted July 3, 2007 Author Report Share Posted July 3, 2007 Thanks Boris,Can I do a system restore without accessing windows?Hold the F8 key down as its booting to give you access to starting in Safe ModeChoose Safe Mode from the options displayed - and you should get a System Restore option offered thereThanks again guys, I'll give that a shot. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted July 4, 2007 Report Share Posted July 4, 2007 But don't give up on SP2 - it bring many important security fixes to Windows XP.It is very important that you carefully check the computer for malware before installing SP2. Viruses, trojans, spyware - all can have disastrous effects when installing SP2. Most likely Windows will no longer run if SP2 was installed with malware present. Quote Link to comment Share on other sites More sharing options...
