blujakx Posted July 6, 2007 Report Share Posted July 6, 2007 For some reason I no longer have sound recorder. Is there a place on the windows website or anywhere where I can get it? -Thanx Quote Link to comment Share on other sites More sharing options...
andsome Posted July 6, 2007 Report Share Posted July 6, 2007 HERE. Quote Link to comment Share on other sites More sharing options...
Boris Posted July 6, 2007 Report Share Posted July 6, 2007 andsomeI believe that the Sound Recorder being referred to is an integral part of Windows It can normally be found under Programs / Accessories / EntertainmentBrief description of using it hereblujakxDo you still have the actual file ? - which should normally be found in C:\Windows\system32\ - called sndrec32.exeOr is it just the shortcut that is missing ?There are different versions of the file, depending on your Operating System DetailsHave you tried running the XP System File Checker ?Press Start, Run, and then type in SFC /scannow This causes SFC to scan your system immediately. It can take a few minutes to run. It validates the digital signatures of all of the Windows system files and restores any that it finds are incorrect.Have your installation CD available in case SFC needs to replace damaged/missing files. Quote Link to comment Share on other sites More sharing options...
andsome Posted July 6, 2007 Report Share Posted July 6, 2007 andsomeI believe that the Sound Recorder being referred to is an integral part of Windows It can normally be found under Programs / Accessories / EntertainmentBrief description of using it hereblujakxDo you still have the actual file ? - which should normally be found in C:\Windows\system32\ - called sndrec32.exeOr is it just the shortcut that is missing ?There are different versions of the file, depending on your Operating System DetailsHave you tried running the XP System File Checker ?Press Start, Run, and then type in SFC /scannow This causes SFC to scan your system immediately. It can take a few minutes to run. It validates the digital signatures of all of the Windows system files and restores any that it finds are incorrect.Have your installation CD available in case SFC needs to replace damaged/missing files.You are of course correct, and I stand corrected and suitably chastened. :D :D :D Quote Link to comment Share on other sites More sharing options...
Boris Posted July 6, 2007 Report Share Posted July 6, 2007 You are of course correct, and I stand corrected and suitably chastened. :D :D :D :0 I will preserve and frame the above historic statement :lol: Quote Link to comment Share on other sites More sharing options...
andsome Posted July 6, 2007 Report Share Posted July 6, 2007 You are of course correct, and I stand corrected and suitably chastened. :D :D :D :0 I will preserve and frame the above historic statement :lol:Buy a decent quality frame, no cheap rubbish please. :D Quote Link to comment Share on other sites More sharing options...
