ZoOorO Posted July 24, 2007 Report Share Posted July 24, 2007 Hello guys.i installed Windows XP yesterday and everything worked great without the ethernet :Si dont have the local area conection? what am i supposed to do please help me fast ! Quote Link to comment Share on other sites More sharing options...
Boris Posted July 24, 2007 Report Share Posted July 24, 2007 Does your network adapter show OK in Device Manager ? Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted July 24, 2007 Report Share Posted July 24, 2007 If you have reinstalled XP then you need to install the motherboard drivers again and the graphics drivers. Quote Link to comment Share on other sites More sharing options...
ZoOorO Posted July 24, 2007 Author Report Share Posted July 24, 2007 If you have reinstalled XP then you need to install the motherboard drivers again and the graphics drivers.yeah i installed everything but i dont find any prog that i can use to install the ethernet :Si didnt get a cd with the pc :S:SPlease help man! Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted July 25, 2007 Report Share Posted July 25, 2007 If you can, download this program, (or get a friend to) install it and run the program, check motherboard and that will tell you what your board is then you can search for the drivers.http://www.majorgeeks.com/download4181.htmlDid you check what Boris asked about the network adaptor in device manager. Quote Link to comment Share on other sites More sharing options...
Boris Posted July 25, 2007 Report Share Posted July 25, 2007 Also, is your onboard network enabled in the BIOS ? Quote Link to comment Share on other sites More sharing options...
