deuces wild Posted August 4, 2007 Report Share Posted August 4, 2007 We have a computer in a spare bedroom and it will not allow me to install and run a defrag program. When I tried to install Perfect Disk I am told the HD is locked. When I open the program the HD is not recognized. When I tried to install Diskeeper I get the following error message and it will not finish the installation:Error 1920. Service Diskeeper failed to start. Verify that you have sufficient priveleges to start system services.Any ideas? Quote Link to comment Share on other sites More sharing options...
Boris Posted August 4, 2007 Report Share Posted August 4, 2007 You need to install these from an Admin user ? Quote Link to comment Share on other sites More sharing options...
Boris Posted August 4, 2007 Report Share Posted August 4, 2007 I also believe that Diskeeper requires the "Event Log" Service running - to work ?If so you will have to "START" Event Log Service and set its start type to "Automatic" Quote Link to comment Share on other sites More sharing options...
deuces wild Posted August 4, 2007 Author Report Share Posted August 4, 2007 I also believe that Diskeeper requires the "Event Log" Service running - to work ?If so you will have to "START" Event Log Service and set its start type to "Automatic"That did it. Thanks!!! Quote Link to comment Share on other sites More sharing options...
Boris Posted August 4, 2007 Report Share Posted August 4, 2007 Thanks, - I like the easy ones :) Quote Link to comment Share on other sites More sharing options...
