php111 Posted September 8, 2007 Report Share Posted September 8, 2007 Hi,How do i take the 3 floppy files of MS-DOS 6.22 and how do i create an bootable CD? I know many of years ago in my first PC it had an floppy drive so that was easier but this PC does not have a floppy drive. If i make DOS on a CD do i need to create it as 3 CD's just like floppies? Would it prompt me for all 3 CD's? I know it prompts for all 3 floppies. Quote Link to comment Share on other sites More sharing options...
Boris Posted September 8, 2007 Report Share Posted September 8, 2007 Pardon my ignorance, but why on earth do you want to do this ? :0 Quote Link to comment Share on other sites More sharing options...
php111 Posted September 8, 2007 Author Report Share Posted September 8, 2007 Pardon my ignorance, but why on earth do you want to do this ? :0Do you mean why do i want DOS? Well i just want DOS and i want to dual boot Vista and DOS. Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 8, 2007 Report Share Posted September 8, 2007 Would MS DOS 6.22 be aware of the existence of CDs?The boot software is downloadable from http://www.svrops.com/svrops/dwnlddisk.htm (scroll two thirds down the page).I'm doubtful it will be usable in the way you want.Does seem very strange - sort of ancient and modern Quote Link to comment Share on other sites More sharing options...
php111 Posted September 8, 2007 Author Report Share Posted September 8, 2007 Would MS DOS 6.22 be aware of the existence of CDs?The boot software is downloadable from http://www.svrops.com/svrops/dwnlddisk.htm (scroll two thirds down the page).I'm doubtful it will be usable in the way you want.Does seem very strange - sort of ancient and modernThat doesn't help me. How do i get MS-DOS on a CD? Quote Link to comment Share on other sites More sharing options...
Boris Posted September 8, 2007 Report Share Posted September 8, 2007 Alternatively you could use a USB floppy drive to install from your existing disks ? Quote Link to comment Share on other sites More sharing options...
php111 Posted September 8, 2007 Author Report Share Posted September 8, 2007 Alternatively you could use a USB floppy drive to install from your existing disks ?I don't have the money for a USB drive and i rather put it on CD. Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 8, 2007 Report Share Posted September 8, 2007 I've given you a link from which it can be downloaded all you have to do then is burn it to a CD.I'm very doubtful about this whole notion, though. Quote Link to comment Share on other sites More sharing options...
Boris Posted September 8, 2007 Report Share Posted September 8, 2007 Why not fit a normal floppy drive in your PC (if the motherboard has a connector)or .............. USB floppy drive - only £16.99 (delivered) :)http://www.storagedepot.co.uk/USB-and-Fire...CFQQdEgodzxvNwQ Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 8, 2007 Report Share Posted September 8, 2007 Having just read your other current query, are you sure you want to do this? You could easily wreck the whole system if it goes wrong.Even if you do go ahead, learn a bit more about Vista first and also ensure you have full backups of your working system. Quote Link to comment Share on other sites More sharing options...
Boris Posted September 8, 2007 Report Share Posted September 8, 2007 Or does this give you any help ?http://www.allbootdisks.com/Languages/nl/cd_creation.html Quote Link to comment Share on other sites More sharing options...
