TERBOW Posted August 3, 2003 Report Share Posted August 3, 2003 Hi , a little info please.A cd writer burns data without any error messages,but on completion,the pc cannot find anything on the cd,any ideas or suggestions :unsure: system/ windows xp pro. 128mb ram/ 20gig hdd 80% free space-cpu pentium111.tried burning at slower speeds,makes no difference,also tried nero and easy cdall with latest drivers for xp pro. Quote Link to comment Share on other sites More sharing options...
Guest LB Posted August 3, 2003 Report Share Posted August 3, 2003 sounds simple but have you checked that you are not simply doing a test burn?? Quote Link to comment Share on other sites More sharing options...
TERBOW Posted August 3, 2003 Author Report Share Posted August 3, 2003 Lived Backwards,thanks for your reply,yep checked that even ask if i wish to burn another copy! Quote Link to comment Share on other sites More sharing options...
Chris Posted August 3, 2003 Report Share Posted August 3, 2003 What are you burning? Quote Link to comment Share on other sites More sharing options...
TERBOW Posted August 3, 2003 Author Report Share Posted August 3, 2003 powerless.thanks for your reply,mp3 and wave files. Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted August 3, 2003 Report Share Posted August 3, 2003 TERBOW, what happens if you write some data files to the disc? And how do your apparently failed discs appear from within your writing software. eg in nero, put the disc in the drive and select medium information. Does it say that the disc already has a session on it?It may be that the discs you are writing need to be finalised, and not left as multi-session.Mr. M. Quote Link to comment Share on other sites More sharing options...
bluesman821 Posted August 3, 2003 Report Share Posted August 3, 2003 TERBOW make sure you finalize the disc Quote Link to comment Share on other sites More sharing options...
madboy33 Posted August 4, 2003 Report Share Posted August 4, 2003 sorry yuo say that you have tried Nero and Easy Cd-creatorhave you tried burning them with Xp's burner? Quote Link to comment Share on other sites More sharing options...
