Preinstalled Vista home premium
CaptnCoffee
hello there!
I just got me a new notebook. Windows home premium was preinstalled and i didnt get a Vista DVD...
my qestion is: If i (by any reson) wants to format my hdd and reinstall vista, since i didnt get a installation DVD, can i download a copy of vista and install with my activation key (which is located under my notebook)??? is it legal? does microsoft have a download for it?
bless up!
Many commercial computer makers give instructions for copying the hidden partition which contains all of the operating system files to enable you to do a recovery operation in the event of a hard drive failure. Check in your computer manual to see if you have this.
Depending on the supplier, it may be possible for you to install a copy of your operating system from a disk and use your current key to activate. You must, however be careful that the replacement is exactly the same version as the original.
Have you tried contacting the manufacturer, and asking them for ONE good reason for not supplying an installation disc? This behaviour is all too prevalent and personally I would tell them what they could do with their product if I could not have an installation CD. :D
Check what is on the recovery disk. Some have a full copy of Windows but are restricted to be used on that particular model computer. Others just have the facility to access a hidden part of the current hard drive.
