BSOD and error messages (XP Home, SP2).
Xylob
I'm having an issue with my HTPC and have found some error messages in the Event Viewer.
I do not know if the two things are related or not, as I can't find much info....
My HTPC randomly crashes/reboots.
Sometimes it happens under 'heavy load'.
Sometimes it happens when the system is basically idle.
I have error reporting turned on, so every time it reboots it asks me if I want to send a report. I say yes and when it's done it opens an internet page that says "This problem was caused by a device driver. Does this information help you?".
NO!! It doesn't freakin' help me...
Which driver? rolleyes.gif There's only a couple hundred... Plus, all of my drivers are signed by Micro$oft, so they should all be just fine and dandy. Right? They wouldn't "bless" a bad driver...
Is there some sort of a log or file buried deep down inside of XP that I can look at to see which freakin' driver is causing this problem?
I was hoping that the Event Viewer could shed some light on the problem, but...
I got nothin'!
Can somebody point me to a good site with definitions for XP error codes?
I've searched repeatedly using Google, Jeeves, and Yahoo and found tons of sites/pages that talk about XP error codes, but none have any information on the error codes I have gotten...
In fact, most of the sites seem to have been copy/pasted from one another.
I even tried searching the actual error codes I have and got nothing.
Or, if you are a magical elf from Micro$oft and can read their language, my errors are as follows:
Error code 10000050, parameter1 8b23b128, parameter2 00000000, parameter3 f7b725d0, parameter4 00000000.
Error code 1000000a, parameter1 c1010490, parameter2 00000001, parameter3 00000000, parameter4 804e70d5.
TIA!
Yep ! Good those error codes aint they.
There is such a wide variety of things that can cause an operating system to crash that it is like looking for a needle in a haystack sometimes.
Although you get drivers from a reliable source even they can become corrupted. Gonna make a few suggestions. You have got to make a start somewhere in hunting this down, and it can be a process of elimination. You will hopefully see more results from this than trying to hunt down error codes.
DEFRAG - DISK CLEANER -CHKDSK- REMOVE UNWANTED PROGRAMS They are all things you can do from within Windows.
Download and install: ***EASY CLEANER*** (This is free) you can use everything in there to have a good cleanup of registry etc: Do not click on duplicates !. Everthing else is very safe.
Download and install: ***REGISTRY DEFRAG TOOL*** (Again free)
Have you thought about using System Restore to get back to a time when the computer was ok ?
Try to eliminate things one by one. When it is all up and running ok again think of investing in Norton Ghost or Acronis True Image for the future. Saves a whole lot of time.
I find this website very useful....
LOOK HERE
I defrag regularly and use MS's disk cleaner (cleanmgr.exe) once a week and have uninstalled all programs that I don't want/need.
I also regularly clean and defrag my registry with a variety of tools and even defrag my page file when needed.
System restore won't do much as this has always been an issue on this particular PC. I have reformatted the hard drive (as well as replaced the C drive) and re-installed XP at least 3 times on this particular machine. I'm thinking it could be a hardware conflict(???), especially since it's always a "device driver" message.
I'll check that link for the error code info I rene posted and hopefully it will shed some light.
thanks guys and keep the info coming!
