Office Outlook 2007 Password problem
keima
Hi Guys,
i am having trouble with outlook asking me for my network password every time i open it.
It will not accept my password and i cannot seem to re set it.
outlook help file suggests Microsoft Knowledge Base article 290684 which is to delete a registry entry.
i have tried this and always recieve the message 'error occured while delaeting key'
i cannot find out any more, hope someoe can help??
Thanks
Hello Keima, welcome to the forum. :D
Which Windows platform are you using?
In the Knowledge Base article, it does say to backup the registry.
Did you by any chance do that?
Hi Irene,
THanks for your reply.
I am using Win XP Pro SP2
and yes i did make a backup but that was before i tried to delete the key, so the problem in the registry will be also in the back up files
There is a lot of information in the Knowledge base reference.
Did you print it off before you started?
Go through the steps and confirm that you are happy with the steps that you took.
There are other Members on the forum who are more experienced in registry matters than I, so please be patient and wait for other responses.... some are in opposite timescales to the UK. :D
Outlook does not need a password to start up, but it needs a password to connect to the mail server. If you don't know that password, no registry editing will help you. (KB290684 is about Outlook not retaining a password.)
What is your Outlook setup - POP/SMTP, IMAP, or Exchange Server? (Check in Control Panel | Mail if you are unsure.)
P.S. you need to contact your mail admin or ISP to have your mail server password reset.
Hi Guys,
Thank you all for your thoughts on this.
I have now resolved the problem by resetting my permisions and then delaeting the registry key outlined in the Microsoft knowlege base.
After then re entering my details in outlook, all is OK :D
