theguy Posted April 12, 2008 Report Share Posted April 12, 2008 right, ive tried reinstalling it but it still wont work, what now? i dont want to do system restore btw Quote Link to comment Share on other sites More sharing options...
Irene Posted April 12, 2008 Report Share Posted April 12, 2008 right, ive tried reinstalling it but it still wont work, what now? i dont want to do system restore btwYou don't actually say what problems...Could you explain further? Quote Link to comment Share on other sites More sharing options...
theguy Posted April 12, 2008 Author Report Share Posted April 12, 2008 one day i installed realtek HD vista driver, but i didnt kno i already had it, for some reason it stopped my sound working, and then i tried to reinstall it, but after that my sound STILL didnt work Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted April 13, 2008 Report Share Posted April 13, 2008 Did you try to uninstall it (revert to the original driver)? Quote Link to comment Share on other sites More sharing options...
andsome Posted April 13, 2008 Report Share Posted April 13, 2008 right, ive tried reinstalling it but it still wont work, what now? i dont want to do system restore btwWhy not? :D Quote Link to comment Share on other sites More sharing options...
theguy Posted April 13, 2008 Author Report Share Posted April 13, 2008 cos i downloaded antivirus, antispyware, firewall, defragmenter and generally made a lot of changes to my computer which system restore would just get rid of if i used it to restore Quote Link to comment Share on other sites More sharing options...
andsome Posted April 13, 2008 Report Share Posted April 13, 2008 cos i downloaded antivirus, antispyware, firewall, defragmenter and generally made a lot of changes to my computer which system restore would just get rid of if i used it to restoreBest to burn all your downloads to CD, then install them. :D Quote Link to comment Share on other sites More sharing options...
theguy Posted April 15, 2008 Author Report Share Posted April 15, 2008 now it doesnt work, its been too long so my system restore cant restore back to the date before all this happened!!any other way of fixing my problem? I REALLY WANT MY SOUND BACK!!!! :( Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted April 16, 2008 Report Share Posted April 16, 2008 It cannot be that difficult; if you install the correct driver for an existing device, it will just work. It will not work if the driver, device, and operating system don't match. Quote Link to comment Share on other sites More sharing options...
