icarus Posted April 22, 2008 Report Share Posted April 22, 2008 I'm desperate. I am. 2 days ago I just reinstalled Windows Xp SP2 and everything was going so smoothly. 2 days of heaven. Until now as my computer started restarting like crazy out of nothing. 3 mins after a restart and another one follows with a BSOD and the error: "DRIVER_IRQL_NOT_LESS_OR_EQUAL ; STOP 0X000000D1 ( 0X00000002, 0X 00000000, 0X85BA2D43) . After some research i found that this is my problem: http://support.microsoft.com/kb/925922/en-us. I installed the indicated KB, the tcpip.sys file specified in the article was created...but afterwards.....other Reboots followed. How can I fix this problem???? Quote Link to comment Share on other sites More sharing options...
-pops- Posted April 22, 2008 Report Share Posted April 22, 2008 As a tryout, remove all USB devices. If you have USB mouse/keyboard than replace them with PS2 types if possible.If it goes OK without the USB devices attached, it indicates there is a problem with one or more of those. No point in going into a lot of detail before you've tried that but you might want to look athttp://www.techsupportforum.com/microsoft-...0x000000d1.htmlAlso, do you have all the Windows updates installed? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted April 22, 2008 Report Share Posted April 22, 2008 The system attempted to access pageable memory using a kernel process IRQL that was too high. The most typical cause is a bad device driver (one that uses improper addresses). It can also be caused by caused by faulty or mismatched RAM, or a damaged pagefile.http://www.aumha.org/a/stop.phpCheck:http://support.microsoft.com/kb/873152/en-ushttp://support.microsoft.com/kb/925922/en-ushttp://support.microsoft.com/kb/916595/en-us Quote Link to comment Share on other sites More sharing options...
