xsystemx Posted June 24, 2008 Report Share Posted June 24, 2008 Hi everyone,We have a few workstations that hotfix KB946976 is causing problems and needs to be removed once a week after automatic updates are completed.I was wondering if there is a command/script that would enable me to remove a hot fix?Something similar to : msiexec /p STD.msi /x EXCEL.msp /qb- REBOOT=ReallySuppressAlso, I've read that hotfix.exe might offer the functionality but I have not been able to figure i out...Here is a listing of the files that came with this particular hotfix:EXCEL.mspohotfix.exeohotfix.iniohotfixr.dllThanks. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted June 24, 2008 Report Share Posted June 24, 2008 You might see if Windows Power Shell (free Microsoft utility) lets you do what you're attempting. Sorry I don't know how to offer specific advice for you.http://www.microsoft.com/windowsserver2003...ll/default.mspxIt is probably possible to do what you want without having to resort to using Power Shell. Are you running Active Directory? What Server environment? Quote Link to comment Share on other sites More sharing options...
xsystemx Posted June 24, 2008 Author Report Share Posted June 24, 2008 Windows 2000 ServerYou might see if Windows Power Shell (free Microsoft utility) lets you do what you're attempting. Sorry I don't know how to offer specific advice for you.http://www.microsoft.com/windowsserver2003...ll/default.mspxIt is probably possible to do what you want without having to resort to using Power Shell. Are you running Active Directory? What Server environment? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted June 24, 2008 Report Share Posted June 24, 2008 http://support.microsoft.com/kb/262841 and http://support.microsoft.com/kb/184305/ Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted June 25, 2008 Report Share Posted June 25, 2008 KB946976 is not a hotfix, but a regular security update; I do not recommend that it is routinely removed after AU/MU/WU. I would rather look how to fix the "problems" in a regular way, rather than by removing security updates. Quote Link to comment Share on other sites More sharing options...
xsystemx Posted June 25, 2008 Author Report Share Posted June 25, 2008 Thanks for all the great feedback.The problem is that this update/hot fix is affecting excel documents that are pre-generated by a certain service for our company.The excel spreadsheet works fine with the current version of excel.... but when the second the update is applied, it does not work anymore...The layout is all off..Anyone know how to block a specific security update with Windows 2000 server AD or how to remove it using a script? KB946976 is not a hotfix, but a regular security update; I do not recommend that it is routinely removed after AU/MU/WU. I would rather look how to fix the "problems" in a regular way, rather than by removing security updates. Quote Link to comment Share on other sites More sharing options...
xsystemx Posted June 25, 2008 Author Report Share Posted June 25, 2008 I have found a script that might do the trick, can anyone confirm?Set objCollection = CreateObject("Microsoft.Update.UpdateColl")Set objSearcher = CreateObject("Microsoft.Update.Searcher")Set objResults = objSearcher.Search _ ("UpdateID='Windows XP KB912812'")Set colUpdates = objResults.UpdatesWscript.echo colUpdates.countobjCollection.Add(colUpdates.Item(0))Wscript.echo objCollection.countSet objInstaller = CreateObject("Microsoft.Update.Installer")objInstaller.Updates = objCollectionSet objInstallResults = objInstaller.UninstallWscript.Echo objInstallResults.ExceptionWscript.Echo objInstallResults.RebootRequiredWscript.Echo objInstallResults.ResultCodeI also found this:psexec \\remotemachinename"C:\WINDOWS\$NtUninstallKB912812$\spuninst\spuninst.exe" /quiet/passive /f /norestartI guess I could also execute spuninst.exe locally using a script? Thanks for all the great feedback.The problem is that this update/hot fix is affecting excel documents that are pre-generated by a certain service for our company.The excel spreadsheet works fine with the current version of excel.... but when the second the update is applied, it does not work anymore...The layout is all off..Anyone know how to block a specific security update with Windows 2000 server AD or how to remove it using a script? KB946976 is not a hotfix, but a regular security update; I do not recommend that it is routinely removed after AU/MU/WU. I would rather look how to fix the "problems" in a regular way, rather than by removing security updates. Quote Link to comment Share on other sites More sharing options...
Irene Posted June 25, 2008 Report Share Posted June 25, 2008 KB976476 states that it is a prerequisite to have Windows XP (SP3) installed. Could that be the problem?Might be worth reading through the link above. :) Quote Link to comment Share on other sites More sharing options...
