RedScissors Posted June 30, 2008 Report Share Posted June 30, 2008 I'm having a bit of trouble dual booting XP alongside Vista on my Samsung HD501LJ which I fitted yesterday (29/06). I manage to boot on the disc and go through one of the stages of installation but when it restarts to do more I get the following:Verifying DMI pool data ............Disk read error. Press CTRL+ALT+DEL to restartI consulted my CMOS to find that...> IDE Channel 0 Master [LITE-ON DVDRW SHW-16]> IDE Channel 0 Slave [ none]> IDE Channel 2 Master [samsung HD501LJ]> IDE Channel 3 Master [ none]I can't remember the configuration for when my old HD was in there but something tells me that the HD should be at the top (I'm not at all familiar with this).If anyone has any suggestions I'll be glad to know of them, thank you. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted July 1, 2008 Report Share Posted July 1, 2008 Very strange to have 3 IDE channels on a motherboard, normally it is IDE 0 master / Slave and IDE 1 Master / Slave, unless you have a PCI / IDE card fitted.Have you tried swapping over the connections for IDE Channel 0 Master [LITE-ON DVDRW SHW-16] and the IDE Channel 2 Master [samsung HD501LJ] on the motherboard. Quote Link to comment Share on other sites More sharing options...
Boris Posted July 1, 2008 Report Share Posted July 1, 2008 Can you just clarify which O/S you have been able to partly install ? XP or Vista ?Don't forget that XP will need you to load the SATA drivers for your Samsung HD501LJ Quote Link to comment Share on other sites More sharing options...
RedScissors Posted July 2, 2008 Author Report Share Posted July 2, 2008 Alan2273:I would try swapping the connections but they don't fit in each other.Boris:Trying to install XP, Vista is already installed. I've already ruled out the possibility of the hard drive being faulty because the drive works perfectly under Vista.Very good idea about the loading of the SATA drivers. I didn't have to do that with my last drive but I'll give it ago this time.Also, might want to mention that I actually want to triple boot with some Linux distro too but it has been tested on this drive and it "Just Works" ;)Thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
RedScissors Posted July 2, 2008 Author Report Share Posted July 2, 2008 Just tried loading the drivers, I'm assuming that I pres F6 when prompted by the XP install; it asked me for software that came with the drive but there is none. Quote Link to comment Share on other sites More sharing options...
Boris Posted July 2, 2008 Report Share Posted July 2, 2008 I'm assuming that I press F6 when prompted by the XP installYesRead this about how you should dual boot XP + Vista (where Vista is installed first) :-http://apcmag.com/how_to_dual_boot_vista_a...ystep_guide.htmYou will normally be able to download SATA drivers for your H/D from its manufacturer's website Quote Link to comment Share on other sites More sharing options...
