Sound question?
dinosaw
Hi all, i have a computer :), and i have two audio outputs. one on the front and one on the back frm the mainboard. I get great sound from the front output but when i plug speakers into the rear output only get the left speaker playing? is this a balance thing. Ive gone through volume control and made sure all optoins were balanced correctly and volume was up.
Any ideas?
Cheers
If you made all the appropriate adjustments on your controls for the rear speakers to make them the same as for the front & still one of the rear speakers doesn't work there must be a hardware problem with that rear connection. To check you could also try with a different pair of speakers.
