El Magnifico Posted September 4, 2008 Report Share Posted September 4, 2008 Hey all..I need to create new keyboard shortcuts to access programs and do stuff..Can I add new shortcuts using the FN Key other than those predefined by the manufacturer?I was able to create shortcuts with ctrl+alt using some software but I need to know if I can do the same with the FN Key..Thanks in advance.. Quote Link to comment Share on other sites More sharing options...
andsome Posted September 5, 2008 Report Share Posted September 5, 2008 I open Start/All programs, then right click on the required program and there is a selection available for 'create a short cut'. Click on this then drag the shortcut to the desktop. :D Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted September 5, 2008 Report Share Posted September 5, 2008 The only user keyboard shortcuts I know of are the Ctrl+Alt+? ones. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted September 5, 2008 Report Share Posted September 5, 2008 http://www.edbott.com/weblog/archives/000683.html Quote Link to comment Share on other sites More sharing options...
El Magnifico Posted September 5, 2008 Author Report Share Posted September 5, 2008 Aha..So it seems not possible using FN Key..Thanks for the help..:) Quote Link to comment Share on other sites More sharing options...
