Boris Posted September 11, 2008 Report Share Posted September 11, 2008 Friend just rang me with an interesting one. He is unable to access either of these two web pagesMicrosoft Updatehttp://update.microsoft.com/microsoftupdat...t.aspx?ln=en-usorWindows Updatehttp://windowsupdate.microsoft.com/He has tried it using these browsers :-IE7SlimBrowserFirefox 3 (with IE Tab add-on)and each time the hour-glass appears, it says "waiting for ..........", then the browser just hangs.Every other page he tries to access works perfectly.Any ideas ?Oh ............. he is using XP Pro with SP3 and had no trouble installing 2 updates last week. Quote Link to comment Share on other sites More sharing options...
Boris Posted September 11, 2008 Author Report Share Posted September 11, 2008 Just got him to run Belarc Advisor and he's sent me the screen shot below, showing that the only hot-fixes he does not have installed are the ones below - all released this week. Quote Link to comment Share on other sites More sharing options...
Boris Posted September 11, 2008 Author Report Share Posted September 11, 2008 Right I've narrowed it down a bit :)His Automatic Updates Service Startup Type is Automatic .................... but it seems to be stuck on "Starting", and is not "Started" Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted September 11, 2008 Report Share Posted September 11, 2008 Dial-a-fix :DSite note: You should also try https://update.microsoft.com (notice the HTTPS). Quote Link to comment Share on other sites More sharing options...
Boris Posted September 12, 2008 Author Report Share Posted September 12, 2008 Thanks NickDial-a Fix didn't resolve it. I spent all day over there today and the only solution in the end after numerous System Restore attempts was to go back to an image he took of his C:\ drive about 3 months back and then update everything else from then. Luckily all his data was on D:\ :) :) Quote Link to comment Share on other sites More sharing options...
