SP2 Installation problem!
Hi there!
Recently I was a silly boy and downloaded an application without scanning it for a virus and hence my computer became a useless heap of bleeps and funny icons within minutes.
Luckily I'm not that daft and keep all my windows files seperate from everything else so I reinstalled my windows XP Pro but I am having immense trouble installing Service Pack 2.
Everytime I download it and run the program it says "File Is Corrupt" about halfway through the extraction. It doesn't matter how many times I download it or from where I still get the same thing.
I had partial success when I went into safe mode and emptied my temp folders, but even then I only got so far and that has no effect at all now.
Can anyone help me? I can't install my graphics card because it requires a feature that requires SP2 and I can't get other things like Live Messenger either and it's driving me mad.
I'm running an Intel Pentium 4, 3.00GHz, 1.5GB ram if that helps.
Thanks!
Did you d/l SP2 using a download manager (using multi-threading) ?
Using the basic "Save As" gives less chance of the .exe being corrupted.
Hey thanks for the quick reply. I downloaded the file from the microsoft site using the standard "Save as" downloader. I really don't think it is the file as I used the same one I downloaded a few times and it had varying stages of success every time, but nothing solid, and then after multiple downloads from the microsoft site and various other ones it's still exctly the same problem.
You say that you reinstalled XP. Did you format the drive and do a fresh install, or did you run the CD over the previous installation? I have reinstalled XP several times after a format and have NEVER had any bother at all. I believe that trying to reinstall on top of the previous installation can be very bothersome, and cause the type of problem that you are getting. :D
Yes the installation was a completely fresh one over a formatted drive! This is why I cannot understand what is wrong!
