Hb_Kai Posted October 18, 2008 Report Share Posted October 18, 2008 I've been using a Micro SD memory card for my phone for ages, and since I got it I've always used the PC's memory card reader to put the card in so I can change the files I have on there but recently it hasn't been working properly.The only problem I'm having with it now is that when I put the memory card into the slot where it should be, the light comes up as it always used to but it doesn't come up in My Computer so I can't get to the files on the PC.I've taken the side of the tower off to check if any wires have come loose but there ain't a problem there aswell.Is there another thing I can do or is it just broken? :S Quote Link to comment Share on other sites More sharing options...
Andras Posted November 5, 2008 Report Share Posted November 5, 2008 I've been using a Micro SD memory card for my phone for ages, and since I got it I've always used the PC's memory card reader to put the card in so I can change the files I have on there but recently it hasn't been working properly.The only problem I'm having with it now is that when I put the memory card into the slot where it should be, the light comes up as it always used to but it doesn't come up in My Computer so I can't get to the files on the PC.I've taken the side of the tower off to check if any wires have come loose but there ain't a problem there aswell.Is there another thing I can do or is it just broken? :SYou can try your SD card in another PC with card reader slot or connect an external USB card reader. Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 5, 2008 Report Share Posted November 5, 2008 Your card may not be USB but the same could apply as in http://forums.windowsforum.org/index.php?showtopic=32464 Quote Link to comment Share on other sites More sharing options...
