daufoi Posted November 19, 2008 Report Share Posted November 19, 2008 Hello,My screen resolution is set to native resolution of 1680x1050. When my computer goes to standby, it resets to 1280x1024. How can I keep it on 1680x1050?I have Windows XP Pro, Intel onboard graphics card, HP lcd monitor. Quote Link to comment Share on other sites More sharing options...
andsome Posted November 19, 2008 Report Share Posted November 19, 2008 Right click on the desktop and select Properties/Settings/Advanced/Monitor. Then tick the box which says "Hide modes that this monitor cannot dis[lay". Then go back one window and select the resolution that you want. Then you must click apply followed by OK. :D Quote Link to comment Share on other sites More sharing options...
daufoi Posted November 19, 2008 Author Report Share Posted November 19, 2008 Right click on the desktop and select Properties/Settings/Advanced/Monitor. Then tick the box which says "Hide modes that this monitor cannot dis[lay". Then go back one window and select the resolution that you want. Then you must click apply followed by OK. :Dwhat if that check box is grayed out? Quote Link to comment Share on other sites More sharing options...
andsome Posted November 19, 2008 Report Share Posted November 19, 2008 Right click on the desktop and select Properties/Settings/Advanced/Monitor. Then tick the box which says "Hide modes that this monitor cannot dis[lay". Then go back one window and select the resolution that you want. Then you must click apply followed by OK. :Dwhat if that check box is grayed out?I don't know, I have never had this problem. Do you have the monitor drivers installed? :D Quote Link to comment Share on other sites More sharing options...
daufoi Posted November 19, 2008 Author Report Share Posted November 19, 2008 Right click on the desktop and select Properties/Settings/Advanced/Monitor. Then tick the box which says "Hide modes that this monitor cannot dis[lay". Then go back one window and select the resolution that you want. Then you must click apply followed by OK. :Dwhat if that check box is grayed out?I don't know, I have never had this problem. Do you have the monitor drivers installed? :DYes, it's the drivers that come with the monitor Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 20, 2008 Report Share Posted November 20, 2008 Have you tried to update to the newest video adapter and monitor drivers? -> http://www.drivermax.com/ Quote Link to comment Share on other sites More sharing options...
daufoi Posted December 4, 2008 Author Report Share Posted December 4, 2008 Have you tried to update to the newest video adapter and monitor drivers? -> http://www.drivermax.com/i do have the latest drivers for both my monitor and my graphics card Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted December 4, 2008 Report Share Posted December 4, 2008 are there settings which change everything after using standby which you might be able to change to keep the resolution how you want after standby.I've never had a problem like this or never seen any "standby" settings, but there might be. Quote Link to comment Share on other sites More sharing options...
