KeithA45 Posted January 26, 2009 Report Share Posted January 26, 2009 I'd like to be able to remotely connect to my home desktop PC from my work PC. Both are running XP SP3. However, due to VERY high security settings on my work computer I CANNOT install any software on my work PC, even to join a virtual network.I've looked up instructions for using Remote Desktop Connection but I just can't get it to work.Can I get human instructions for how to do it?Also, 2 other things:Can I do it from home as well (my laptop in my bedroom to my desktop in the other room)? Should I use different settings if I do?and Do I have to logoff/lock my desktop PC to make it remotely connectable? I know I'm supposed to, but will it work if I don't?Thanks in advance, - Keith Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted January 26, 2009 Report Share Posted January 26, 2009 www.logmein.com is useful for this. I can't remember if you have to download anything but it's easy to use and free. Quote Link to comment Share on other sites More sharing options...
catgate Posted January 26, 2009 Report Share Posted January 26, 2009 It just may be that the VERY high security settings on my work computer are intended to prevent what you are trying to do. Why not get someone at work to show you how to do it? Quote Link to comment Share on other sites More sharing options...
