ESITech Posted January 29, 2009 Report Share Posted January 29, 2009 Having trouble exporting an excel file to be viewed in Excel 2000 on Windows 2000. This is the message I get in excel...MIME - Version: 1.0Content-Type: multippart/related; boundary="---=_NextPart_ZBCOEJUVPVABOYGPOEYLFPBNPLJVRVIP"This document is a Web archive file. If you are seeing this message, this means your browser or editor doesn't support Web archive files or you are opening this file in a Microsoft Excel verison prior to 2002 (XP). Do I need add-in's? I have already updated Windows 2000 with SP4 and installed the Compatibility Pack for 2007 and those did not work. I will try updating the Office 2000 suite and see if that helps...but is there any other suggestions you folks to help me with? Quote Link to comment Share on other sites More sharing options...
rong Posted January 29, 2009 Report Share Posted January 29, 2009 You could try Open office to see if it will work in that Quote Link to comment Share on other sites More sharing options...
Irene Posted January 30, 2009 Report Share Posted January 30, 2009 Which version of Excel are you exporting from?Or are you exporting from something else? Quote Link to comment Share on other sites More sharing options...
