lafleur1977 Posted April 4, 2009 Report Share Posted April 4, 2009 HeyCan anybody offer any advice on this scenario please when trying to connect two laptops together."a serial cable which has been adapted from a modem cable, i.e. it has female connectors on both ends."Thanks. Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted April 4, 2009 Report Share Posted April 4, 2009 Considering how low the cost of a crossover cable would be, I'd abandon this adapted cable as a waste of time. The laptops are most likely to have a standard RS232 socket, so you'd probably need two gender changers to plug the cable in, this'll cost more than a new cable.You could also consider a USB transfer cable Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted April 5, 2009 Report Share Posted April 5, 2009 I agree with Belatucadris. Either an Ethernet crossover cable or a USB cable will be much faster and easier to use than a serial cable.If you must use a serial cable, you'll need a null modem cable or adapter, and you'll have to configure the serial port options identically on both computers. Quote Link to comment Share on other sites More sharing options...
lafleur1977 Posted April 7, 2009 Author Report Share Posted April 7, 2009 Thanks to both of you for your help :] Quote Link to comment Share on other sites More sharing options...
