Nickolas Johnson Posted June 1, 2009 Report Share Posted June 1, 2009 =I have a 2.1 speaker/subwoofer system, the Right and Left speakers connect to a powered sub, and the sub connects to the sound card (via the typical 3.5mm connector).One of the the speakers has gone out, so now I only get audio from the left channel. When I play a game or listen to a song that is in stereo, the audio on the right channel is gone. I have gone into control panel and set speaker setup to "Laptop Mono Speaker", but I am still missing audio. For instance, when listening to a song that is in stereo sound, if the singers voice is supposed to come from the right side only, you can't hear him at all. Or when playing a game, if a sound effect is supposed to come out of the right channel, you don't hear the sound.Any way to force Windows to truly merge the channels, so all audio comes out of the one working speaker and sub? Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted June 1, 2009 Report Share Posted June 1, 2009 The mono speaker thing is the only fix I've ever heard of, though I also heard some sound cards don't support mono output which stops it working. If this is the problem then you need to check out what's caused the speaker failure. Quote Link to comment Share on other sites More sharing options...
