Skylinedive Posted June 27, 2009 Report Share Posted June 27, 2009 My roomate just got a new hard drive. I have installed new hard drives and Windows before, no problem. He just got a 1TB Seagate Barraccuda. I have one and it works well. I installed Vista Home Premium 64 on mine and it was fine. When I try to install Vista 64 on his, it gives me an error code of: 0x80070057.This is a new partition that is empty. Oh, and it won't let me format it either. Same error code.Any help? Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted June 27, 2009 Report Share Posted June 27, 2009 Will this help.http://www.tomshardware.co.uk/forum/page-257202_13_0.html Quote Link to comment Share on other sites More sharing options...
catgate Posted June 27, 2009 Report Share Posted June 27, 2009 I installed Vista Home Premium 64 on mine and it was fine. When I try to install Vista 64 on his, it gives me an error code of: 0x80070057.Any help?Using the same CD???? Quote Link to comment Share on other sites More sharing options...
Skylinedive Posted June 28, 2009 Author Report Share Posted June 28, 2009 No, it's not the same disk. We both have a copy of the same OS.Thanks for the link. I'll check it out. Quote Link to comment Share on other sites More sharing options...
Skylinedive Posted June 28, 2009 Author Report Share Posted June 28, 2009 Ok, so I went to the link provided and did a little looking around. Someone had an idea. What I failed to realize is that my roomate didn't get a 1TB HDD... he got a 1.5TB. The idea was to take out a dimm of RAM and to reformat the drive size down to 1TB. I did this. He has about 500GB of unallocated space BUT while partitioning it to 1TB I was able to get the installation working without the error.I guess for future reference, have no more than 1TB in a single drive if you are using Vista... ??? We'll see. Good news is that it's working. That's the important part. Thank you. Quote Link to comment Share on other sites More sharing options...
