zilbermm Posted September 3, 2009 Report Share Posted September 3, 2009 Hi,Is it possible to run two user profiles in Windows XP so that each one will work with a different mouse while the other one is disabled?Thanks Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 3, 2009 Report Share Posted September 3, 2009 Not used two mice but have used a mouse together with a graphics pad and also a mouse with a laptop touchpad - both being connected simultaneously but not used together - it's definitely a case of one or the other.I'm a bit doubtful that two mice of the same type would would together but a wired and a wireless one might be OK. Quote Link to comment Share on other sites More sharing options...
zilbermm Posted September 4, 2009 Author Report Share Posted September 4, 2009 Not used two mice but have used a mouse together with a graphics pad and also a mouse with a laptop touchpad - both being connected simultaneously but not used together - it's definitely a case of one or the other.I'm a bit doubtful that two mice of the same type would would together but a wired and a wireless one might be OK.I don't need them to work simultaneously.when user 1 is logged in to his profile mouse 1 should work, when switching to user 2 then mouse two should work. Quote Link to comment Share on other sites More sharing options...
rong Posted September 4, 2009 Report Share Posted September 4, 2009 As far as I know you can just plug two mice in and they will both work, but if you want one disabled then that is another thing Quote Link to comment Share on other sites More sharing options...
