PROBLEM WITH MS WORD 2000
This one has really got me tied up in knots. I have been using Word 2000 for a number of years and have never come across this happening before.
I have this fairly large Word doc and it is loaded with a lot of pictures and diagrams. This file has existed for quite some time, and is a work in progress that I am in the middle of editing. Now suddenly, after I load the file and display it,I find the pictures and diagrams have all dissapeared (mostly jpeg pics). Another strange thing about this happening is, when I hit the Print Preview symbol, all the pictures are in place ? In order to edit this document I of course need the pictures in place in the Print View.
Just the day before this happened I had been working in the drawing mode in Word 2000, and thought I may have thrown the wrong switch somewhere but after an hour or so of looking and searching, I have not been able to find out where there might be a command that would allow a Word document to show up with all the pictures removed.
Any help would be appreciated.
jplot
jplot
Can you do a system restore to before the problem occured?
Thanks for your efforts to help. I would not want to even try to use some outside the box, program, as what I really was wanting to do is find out where this command, to remove pictures from a document, might be located. I am on a relatively new computer with Vista and do not care to run the system restore either.
I have a Windows 7 disc coming in the mail and will be eager to see what happens to that same Word 2000 file, after I get 7 running.
I might ad that if I use the Word 2007 program that Vista came with, then the pictures all show up. But that program is so far removed with the 2000 that I am familiar with that I would need to learn Word all over again. Progres.
jplot
