jag Posted March 13, 2010 Report Share Posted March 13, 2010 I thought there was a shortcut to open a folder window from within another folder window. For example, if folder A contains Folder B and Folder A is open, I thought there was a way to double-click on B, opening it while leaving A open as well. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 14, 2010 Report Share Posted March 14, 2010 Are you talking about Windows Explorer?Which Windows version? Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted March 14, 2010 Report Share Posted March 14, 2010 thought there was a shortcut to open a folder window from within another folder window. For example, if folder A contains Folder B and Folder A is open, I thought there was a way to double-click on B, opening it while leaving A open as well. Thanks for sharing your thoughts with us ! Is there a question in there somewhere ?Reminded me once again why I gave up answering things on here in the first place. John. Quote Link to comment Share on other sites More sharing options...
rong Posted March 14, 2010 Report Share Posted March 14, 2010 Control panel / folder options / general and tick the box open each folder in it's own window. That's with XP I will look on W7 later when I fire it up, but would think it should be about the same Quote Link to comment Share on other sites More sharing options...
jag Posted March 14, 2010 Author Report Share Posted March 14, 2010 Thanks Rong, but that fixes it so that every occasion that I double click on a folder it opens a new window. I thought the command was something like, hold down the shift key while double-clicking, which doesn't work by the way. Does that sound familiar to anyone? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 15, 2010 Report Share Posted March 15, 2010 Right-click+X does that for me. Quote Link to comment Share on other sites More sharing options...
