problem with my files
Hello there!
Good afternoon
I have problem with my files i forgot where i save it...is there any way on how to put path file location in every files or pages once i print it...
I found some toturial its good and im using it now but how about automatic path file put it in every pages/files...
Particular in Microsoft word , excel, powerpoint and PDF
thanks
Please help...
If you haven't changed it try to save something else and get the path from the save box, you might have to save-as, have you tried windows search if of course you can remember the file name
There used to be a file finding utility, somewhere in the system, that would go and find files containing whatever word or phrases you fed into the finder. You do not say which M$ OS you are using so I can not be sure where you would go to find it. However I feel sure if you have a ferret around you should find it.
When you save your file/s you should indicate where you want the computer to save it/them.
Take control ...be the boss.
