kumarn Posted July 24, 2010 Report Share Posted July 24, 2010 in my Lenovo laptop have 120 GB hard disk. when i purchased the system it have windows recovery feature of Windows Vista (Home Basic). then i have created another drive so recovery feature have been lost. this was the think of previous year.now before one months, i changed drive size and deleted a partition. then a MBR issue was came in my system. and DVD writter are not working.today, i have installed Windows Vista (Home Basic) using a bootable pendrive.now DVD writter read some CD's and some CD's show blank which have data. it does not read any DVD.in Disk Management, it show a drive of 29 GB (show as a Free space in green color) and a size of 11 GB (which may be size of windows recovery feature that has been lost and show with blue color).when i right click on the free space (that is size of 29 GB) to create a new volume, at the end, it give error:there is not enough space avaliable on the disk(s) to complete this operation.i also tried with 28 GB space on this drive but it give same error.when i right to a volume which have size of 11 GB, following option are enabled. Changed drive letter and path, Format, Delete volume, properties and help. disabled option is: open, explore, Mark partition as active, extend volume, shrink volume.when i click to format: it show a error- An unexpected error has occured. Check the system Event log for more information on the error. Close the disk management console, then start the disk management or start the computer.i also tried to create a new volume during windows installation but it give error when i create volume after formatting. i have only format the entire disk. perhaps it would be better option if during installation, i have delete all the volumes and then creates all the volumes with equal sizes of 60 GB to all three volumes. but i was sacred if all the drive deletes and no one be create. beacuse a simple volume is not create during installation, i tried to create a new volume during installation.presently in My Computer, it show two drive C and D, i want to create one another drive.now my query is how use the space of 29 GB and 11 GB to create a new volume.also suggest about DVD writter.please help. Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted July 26, 2010 Report Share Posted July 26, 2010 Hi, and welcome.I have read through your post several times now, and have come to the conclusion that all of your current problems are "Self Inflicted". This in itself is perhaps not a bad thing, because we all learn a lot by making mistakes and correcting them.However. As you started by wiping out a perfectly good recovery partition, went on to damage the MBR, and now have unusable optical drives, it may be a good time to call a halt to your dabbling, and either find a computer savvy friend who can help you. (Two heads are always better than one.) Or take your laptop to a professional person for repair.It should be stated that when you get to a stage where it says "Check the system Event log for more information on the error." - That is exactly what you should have done.If you did indeed do that, and could not understand the explanation, it was a time to stop and re-think about the level of computer education required to carry on.I seem to think that perhaps any advice given to you would probably lead to a downward spiral in actually fixing your computer if you continue to do it yourself.Anyone else here can come up with any suggestions for Kumarn ?John. Quote Link to comment Share on other sites More sharing options...
bludgard Posted July 26, 2010 Report Share Posted July 26, 2010 Hi,kumarn.MANEMAN's advice might not be off the mark.If it's time for professional assistence....Otherwise a lot of research may be in order.The only thing that I can add to this is that you may want to consider a complete cleaning and re-formatting of HD in anticipation of a clean-install of your OS. Quote Link to comment Share on other sites More sharing options...
