dichro1 Posted August 18, 2010 Report Share Posted August 18, 2010 When I call up the Display Properties dialog box and click on the Desktop tab, it takes two and a half minutes for the list and sample of wallpapers available. This is a new behavior. The response used to be few seconds. ???? Any fix? Otherwise the system seems to function OK.Win XP SP3Core 2 duo CPU4 gb RAM Quote Link to comment Share on other sites More sharing options...
-pops- Posted August 18, 2010 Report Share Posted August 18, 2010 If this is very recent, can you carry out a System Restore to a time before it happened? Quote Link to comment Share on other sites More sharing options...
Dencandy Posted September 11, 2010 Report Share Posted September 11, 2010 Have you recently downloaded lots of new pictures? Windows usually treats every single graphic item (escept thumbnails) as potential wallpapers or background displays & will search the hard drive to find and try to offer you all of them. Quote Link to comment Share on other sites More sharing options...
