NEED HELP - No system/flash application/window media player sound!
kennytung
Recently, I just built a new computer system with the following specs:
_i7 930
_Gigabyte X58A-UD3R
_3x2GB ADATA RAM
_Gigabyte 460GTX
I connected my old speakers (SoundMax 5.1) to the new computer with all the required drivers installed from the bundled driver disks. However, as far as I have seen, I CAN ONLY HEAR the sound when playing games, watching .mkv movies using KLite Codec (I also can hear the "bell" sound when using Windows Sound Control to test each speaker). BUT I CANNOT HEAR: the system sound (bootup sound, shutdown, error, notify....), sound of the flash application running on webs (mp3 player, clips, webgames...), sound of the .avi movie playing by either KLite Codec or Windows Media Player.
I tried reinstalling Windows 7 Ultimate 64bit/32bit and still the same. I also tried the drivers taken from Realtek website/Gigabyte website but also the same result.
Can anyone help me with this :((
Hi,kennytung.
For sound:
I'm sure you have tried the basics:--->Start whatever application that you have issues with>click on speaker icon in task tray>select Mixer>check that there are no disabled signs at the bottom of each column.Click on each icon at the top of each column and go through each tab selecting your preferred settings.
For video:
.AVI files play perfectly well on native software in Windows 7 without any additional codecs.I would especially think this to be true on a clean-install.
Maybe there is a compatibility issue with the codec pack installed?
Welcome to Windows Forum.
Please keep us updated.
B)
It turned out that I misconnected the front speakers into the side speaker connections of the main board resulting to the problems that I mentioned above, the speaker now works ok.
Thank for your help anyway bludgard :)
Interesting.
Thanks for the info gentlemen.And the update,kennytung.
