parasita Posted September 13, 2010 Report Share Posted September 13, 2010 playing cod mw2 on my comp when out of the blue a game just ended and it went to a black screen i figured it was just the game and needed time to reload ctrl alt del wasnt allowing me to go to task manager to close cod my only option was to restart the computer... as soon as it prompted me to go into safe mode or not i noticed my keyboard wasnt working so i tried to switch ports still nothing... decided then to try another keyboard nothing... figure ok w/e i have the on screen keyboard thats when i noticed my mouse wasnt working... same dealtried another port then another mouse then a ps/2 mouse... absolutely nothing.... only thing i could do was another restart to see if that would fix the problem ofcourse it didnt... ive tried every usb port availableas well as my ps/2 ports need imidiate help from someone plz... Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 13, 2010 Report Share Posted September 13, 2010 My thoughts are that this is such a huge breakdown that it will be very difficult to offer useful advice on a forum.You would be best having someone to give a hands-on examination.From what you have told us, though, things aren't looking hopeful. Quote Link to comment Share on other sites More sharing options...
parasita Posted September 13, 2010 Author Report Share Posted September 13, 2010 My thoughts are that this is such a huge breakdown that it will be very difficult to offer useful advice on a forum.You would be best having someone to give a hands-on examination.From what you have told us, though, things aren't looking hopeful.its a brand new comp and it was just out of the blue when it happened... Quote Link to comment Share on other sites More sharing options...
bludgard Posted September 13, 2010 Report Share Posted September 13, 2010 Hi,parasita.Was the machine over clocked at the time of the shutdown?Maybe it just overheated? Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 13, 2010 Report Share Posted September 13, 2010 If it's brand new then it appears that there is a fundamental fault with it. Return it to the supplier for replacement under warranty. 1 Quote Link to comment Share on other sites More sharing options...
bludgard Posted September 13, 2010 Report Share Posted September 13, 2010 If it's brand new then it appears that there is a fundamental fault with it. Return it to the supplier for replacement under warranty.Here,here!I concur.Take it back.Best advice you'll get for a new PC. Quote Link to comment Share on other sites More sharing options...
