Help me! Windows 7 blue screen problems!
Micka
System
- Provider
[ Name] Service Control Manager
[ Guid] {555908d1-a6d7-4695-8e1e-26931d2012f4}
[ EventSourceName] Service Control Manager
- EventID 7009
[ Qualifiers] 49152
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x8080000000000000
- TimeCreated
[ SystemTime] 2010-11-17T22:00:55.886007500Z
EventRecordID 4477
Correlation
- Execution
[ ProcessID] 544
[ ThreadID] 3028
Channel System
Computer Mickael-PC
Security
- EventData
param1 30000
param2 Microsoft .NET Framework NGEN v4.0.30319_X64
+ System
- Provider
[ Name] Microsoft-Windows-WER-SystemErrorReporting
[ Guid] {ABCE23E7-DE45-4366-8631-84FA6C525952}
[ EventSourceName] BugCheck
- EventID 1001
[ Qualifiers] 16384
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2010-11-17T21:57:55.000000000Z
EventRecordID 4449
Correlation
- Execution
[ ProcessID] 0
[ ThreadID] 0
Channel System
Computer Mickael-PC
Security
- EventData
param1 0x0000000a (0x0000000000000008, 0x0000000000000002, 0x0000000000000001, 0xfffff80002a8d3d0)
param2 C:\Windows\MEMORY.DMP
param3 111710-38079-01
Binary data:
In Words
0000: 00000000 00000001 00000033 C000CC0C
0008: 00000000 00000000 00000000 00000000
0010: 00000000 00000000
In Bytes
0000: 00 00 00 00 01 00 00 00 ........
0008: 33 00 00 00 0C CC 00 C0 3....Ì.À
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
Try the Debugging Tools for Windows to analyze your minidumps.
/>http://www.microsoft.com/whdc/DevTools/Debugging/default.mspx
Hopefully they will identify the driver which is causing your problem ?
hey man , so i downloaded that but i have no idea where to start:s i mean what do i even do?
