junaidk Posted November 18, 2010 Report Share Posted November 18, 2010 Hello, I just installed 7 today on my pc, its a custom build with a compaq motherboard model: EVO D510 CMT, I need a sound driver, I have tried multiple sites and tutorial, but have not succeeded.The hardware id is:PCI\VEN_1102&DEV_0002&SUBSYS_80611102&REV_07PCI\VEN_1102&DEV_0002&SUBSYS_80611102PCI\VEN_1102&DEV_0002&CC_040100PCI\VEN_1102&DEV_0002&CC_0401Could anyone help!The XP Drivers are here: http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=uk&prodTypeId=12454&prodSeriesId=316510&lang=en&cc=uk Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted November 18, 2010 Report Share Posted November 18, 2010 Not that this will help you much but Win 7 simply found my sound drivers or did it with Win Updates.In fact I find that Win 7 typically finds most drivers.I suppose you have tried searching via Device Manager [to get to Device Manager press start and type Device Manager in search box]Of course it could be that your compaq motherboard does not support Win 7 sound and there are no Win 7 drivers issued by the manufacturer. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted November 18, 2010 Report Share Posted November 18, 2010 The hp site says this:A driver enables your PC to communicate with other hardware or devices. Drivers for Windows 7 may be included in the operating system, distributed via Windows Update , or downloaded from HP. Please note that drivers for Windows 7 are available for select models only.Source Quote Link to comment Share on other sites More sharing options...
junaidk Posted November 18, 2010 Author Report Share Posted November 18, 2010 okay, I also realised I am using a sound card so it may be that the card is not supported Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 19, 2010 Report Share Posted November 19, 2010 Try http://www.drivermax.com/ - it can find drivers for unknown devices.Use the free version that can download up to two drivers per day. Quote Link to comment Share on other sites More sharing options...
junaidk Posted November 19, 2010 Author Report Share Posted November 19, 2010 I did end up finding a driver for my sound card and the sound now works, I also used drivermax but I really did not like it. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted November 19, 2010 Report Share Posted November 19, 2010 I am pleased it all worked out in the end - thanks for letting us know :)[no I cannot get on with drivermax either ] Quote Link to comment Share on other sites More sharing options...
bludgard Posted November 19, 2010 Report Share Posted November 19, 2010 I use DriverMax..My display driver was inactive.Anything I installed from ATI or Windows couldn't get rid of errors in EV and the 2-5 second stall at boot right before Windows goes to the "good" blue screen with the message "Please Wait...". I fought with this for months.No one knew what the cure was.I keep it out of strartup programs. edit:ya'll will be happy to know that I have no events logged since last night.With several shutdowns.:D :lol: Quote Link to comment Share on other sites More sharing options...
