Makcalable Posted December 26, 2010 Report Share Posted December 26, 2010 (For Windows 7) The taskbar isn't just for apps and documents With just a few seconds work you can pin drive icons on the taskbar too. Right click an empty part of the desktop select New - Text File - and rename the file to drive.exe. Drag and drop this onto your taskbar, then delete the original file. Right-click your new "drive.exe" taskbar button, then right-click its file name and select Properties. Change the contents of both the Target and Start In boxes to point at the drive or folder of your choice, and click Change Icon to choose an appropriate drive icon, and you're done - that drive or folder is now available at a click.Hope you found this useful! ;) 2 Quote Link to comment Share on other sites More sharing options...
bludgard Posted December 26, 2010 Report Share Posted December 26, 2010 Didn't have the option to create new text file.I tried other text options and it crashed OO.o.:lol: New>Folder in Windows Seven works fine.Love the action of it.Like a hair trigger for exploring partitions/disks.Whatever....I've got usage for it.Thanks for the lookout,Bugsy.:D +1 Quote Link to comment Share on other sites More sharing options...
Makcalable Posted December 26, 2010 Author Report Share Posted December 26, 2010 Glad i could of service blugard :D Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted December 26, 2010 Report Share Posted December 26, 2010 Hope you found this usefulYes thank you - most useful Quote Link to comment Share on other sites More sharing options...
