mulhearn22 Posted March 20, 2011 Report Share Posted March 20, 2011 Hi,I'm reformatting a computer for sale. I lost the reinstallation cds a while ago, but it's a dell so it has the recovery partition. I found the Factory.wim and converted it to an ISO. I then made a DVD from the ISO. It boots from the DVD, loads file and then shoves me into a command prompt rooted in system32 running the command wpeinit. It runs that, the log says it's successful, but it goes nowhere. Any ideas?TIA,Matt Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted March 20, 2011 Report Share Posted March 20, 2011 I thought the Dell recovery partition was for doing a fresh factory install without the need for a disk, try pressing Ctl/F11 at start up. Quote Link to comment Share on other sites More sharing options...
mulhearn22 Posted March 21, 2011 Author Report Share Posted March 21, 2011 I thought the Dell recovery partition was for doing a fresh factory install without the need for a disk, try pressing Ctl/F11 at start up.Hey,Thanks for the quick reply.I did try that. I tried hitting Ctrl+F11 simultaneously on start up and holding Ctrl and repeatedly hitting F11. Nothing happens. I also tried F8 (saw that one some forum), which didn't work. I can't get into the factory reset, so I resorted to this. Quote Link to comment Share on other sites More sharing options...
-pops- Posted March 21, 2011 Report Share Posted March 21, 2011 Before you spend much more effort on this, consider that if you will be trying to sell this machine (difficult in itself, selling a second hand (= obsolete)) without its relevant disks, I think there will be little interest from prospective buyers. Quote Link to comment Share on other sites More sharing options...
mulhearn22 Posted March 21, 2011 Author Report Share Posted March 21, 2011 Hi,I realize this. Fortunately, I will be selling to someone either I know or someone I know knows. Because of this, if I can get the recovery to work and then make sure all necessary drivers and such are installed, I can create and image and send that along with it. That would be just as good. Quote Link to comment Share on other sites More sharing options...
