AlanHo Posted April 13, 2011 Report Share Posted April 13, 2011 A strange problem has started when I post to the forum - if I attach a link it is inserted at the very beginning of the post - even though the cursor is at the end. I am having to cut and paste it to the required position.This seems to have started since I installed IE9 - though that may just be circumstantial and a red herring...... Quote Link to comment Share on other sites More sharing options...
andsome Posted April 13, 2011 Report Share Posted April 13, 2011 Testing testing testing. This has been written before I attach a link. Ths link should be below.Have a look at this. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted April 14, 2011 Author Report Share Posted April 14, 2011 I just tried again - same thing has happened so I deleted the test link.On two other forums I participate in - the problem does not occur. It's just this forum???? I'm mystified Quote Link to comment Share on other sites More sharing options...
AlanHo Posted April 14, 2011 Author Report Share Posted April 14, 2011 I just had a fiddle with my board settings and ticked :-Enable Visual (RTE) EditorandEnable Flash UploaderLinks are now appearing in the correct place (and the window I type into now shows in the proper text) Quote Link to comment Share on other sites More sharing options...
andsome Posted April 14, 2011 Report Share Posted April 14, 2011 I just had a fiddle with my board settings and ticked :-Enable Visual (RTE) EditorandEnable Flash UploaderLinks are now appearing in the correct place (and the window I type into now shows in the proper text)Just had a look. they were set by default in my settings.B) Quote Link to comment Share on other sites More sharing options...
