Ahluka Posted May 13, 2011 Report Share Posted May 13, 2011 Hey there, i've just joined, and was looking for a general Windows problems forum, and this came up first :P My problem at the moment is with my CD/DVD drive. It seems to read discs fine, and write discs fine, and everything is fine, but then a friend burns a disc from his PC, and it seems to read on every other computer apart from mine? If i burn a CD, it works fine, as well as on other PCs, but if he does it it comes up as blank on my PC.Only thing i can note is that he tells windows to burn like a USB, not a finalized CD-RW (yes i'm talking about CD-RWs here to be more precise). But this still doesn't explain why my disc drive won't read his discs but will other peoples and my own. :\Any suggestions?Thanks,Ricky Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 13, 2011 Report Share Posted May 13, 2011 A first suggestion is to download a more comprehensive set of codecs.Look at http://www.codecguide.com/download_kl.htm which should give you all the codecs you could ever want.Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
pawz7 Posted May 13, 2011 Report Share Posted May 13, 2011 I could learn something here perhaps. I thought that codecs were to address audio and video problems, but pops, you seem to be saying that cd drives use them as well? I did not know that...I thought the problem with cd drives not being able to read disks burned on some-one else's drive related to format issues. Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 13, 2011 Report Share Posted May 13, 2011 Both CDs and DVD use different formats for storing data - as is notable if you have a look at the link I gave in my first reply - with DVDs there are dozens of formats in use.I does no harm to have the K-Lite pack on your machine(s). It takes up little space and can be a great help in getting difficult disk to play.K-Lite doesn't always remedy a problem,though. There are instances where there is an error in the disk player/writer itself but trying a codec collection as a first attempt at a cure will do no harm at all, may do a lot of good and will be useful in the future anyway. Quote Link to comment Share on other sites More sharing options...
pawz7 Posted May 13, 2011 Report Share Posted May 13, 2011 thank you pops. I did have the K-Lite pack of codecs on my machine a while back as someone recommended it - and it was quite a large download I seem to recall, but i never seemed to need it, so got rid of it again; perhaps i will go get it once more :) Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 13, 2011 Report Share Posted May 13, 2011 When you have K-Lite installed it works silently doing its job when needed and you don't really know it's there but you would soon know if it was absent! Quote Link to comment Share on other sites More sharing options...
pawz7 Posted May 13, 2011 Report Share Posted May 13, 2011 right... I will give it a go :) Quote Link to comment Share on other sites More sharing options...
wisho0 Posted May 17, 2011 Report Share Posted May 17, 2011 Maybe download a decoder is effective Quote Link to comment Share on other sites More sharing options...
spa mumbai Posted June 1, 2011 Report Share Posted June 1, 2011 Hi, may be the folder written in the disc is hidden. Go to the tools >>folder Option >>View >>Show hidden files and folders then press OK.Try this may be this will work. Quote Link to comment Share on other sites More sharing options...
