Install XP Pro on an external USB Hard Drive?
shokan
Is there any reason I cannot format, and install XP on, this external drive?
Iomega 320GB eGo USB Hard Drive
Key Features
Capacity: 320 GB
Interface: USB · FireWire
Enclosure: External
Spindle Speed: 5400 RPM
Technical Features
Buffer Size: 8 MB
Average Latency: 5.56 ms
Interface (Detailed): FireWire 400 (1394a) · USB 2.0 · FireWire 800 (1394b)
Other Features
Compliant Standards: Plug and Play
I'm not looking for performance, just for having XP on another drive separate from the main HD. If I can do this, how will I do it when booting my machine with the XP full install disc (XP will already be on the main machine HD)? Will the screen show an option of the ext drive to format and to install?
Thanks.
A few points first of all:
1. Does the BIOS/motherboard of the computer have built-in USB capability? It used to be that USB was a function of the operating system and only became operable when the O/S was fully loaded.
2. WXP was very particular where and at what stage it was installed. If you are trying to install alongside another Windows version, it could be that which is preventing the operation.
3. I'm not familiar with that Iomega drive but I recall from the past with other hardware from the same manufacturer that they always had their own driver software which needed to be loaded before Windows could see the item. Is that the case here?
Documented General Info:
Processor
• Socket: 775
• Supports the following processors:
-Pentium D 900 series Dual Core (Presler)
-Pentium D 800 series Dual Core (Smithfield)
-Pentium 4 500 (Prescott)
-Pentium 4 600 (Prescott)
-Celeron D (Prescott)
-Celeron D (Cedar Mill)
Chipset
• Northbridge: ATI RC410
• Southbridge: ATI IXP450
Memory
• Single-channel memory architecture
• 2 x 240-pin DIMM sockets support unbuffered non-ECC 400/533 MHZ DDR2 memory modules
• Maximum memory is 2 GB
Audio
• Built-in Azalia 8 channel audio
• Realtek ALC882 or ALC883 8-channel High Definition Audio CODEC
Onboard I/O Connectors
• Supported by Intel®ICH7
- 2 x Ultra DMA100/66 devices
- 4 x Serial ATA2 devices
Peripheral Interface [internal/Rear Panel]
Two IDE connectors
One floppy drive connector
One ATX 24-pin power connector
One ATX 4-pin +12v power connector
Four Serial ATA connectors
One VGA connector
One IEEE 1394a connector
One CPU fan connector
One PC fan connector
One CD_IN connector
One front panel audio connector
One PC panel connector
Two USB connectors supporting 2.0 ports
PS/2 keyboard (purple)
PS/2 mouse (green)
One SPDIF out port
One S-video out port
One VGA out port
One Parallel port
Four USB (2.0)
One IEEE 1394a
One RJ-45 networking port (LAN)
Audio ports:
line in (light blue)
line out (lime)
microphone (pink)
side speaker out (gray)
rear speaker out (black)
center/subwoofer (yellow orange)
Expansion Slots
• 1 x PCI Express x16 slot
• 2 x PCI slots
BIOS
• AMI BIOS with 4Mb Flash ROM
• Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
• Supports ACPI revision 1.0 specification
Onboard LAN
• Realtek RTL8100 10/100 Mbps Fast Ethernet controller
Video
• Integrated RC410 on-chip (Radeon X300-based 2D/3D graphics)
Form Factor
microATX (9.60 inches by 9.60 inches [244 millimeters by 244 millimeters])
Not sure and don't know how to check.
Nothing came with the retail drive.
