chocony Posted November 5, 2011 Report Share Posted November 5, 2011 I usually do my beginner Java Console Practice using Command Prompt as the compiler.But there is a problem, my Command Prompt can't read ASCII. It's because there is no Lucida Console font in the Command Prompt. Previously I had installed Japanese Language bar to my Laptop, but it makes strange symbol in my Words, so I decided to uninstall it. But the Japanese fonts doesn't get removed. The " \ " symbol still changed into yen symbol. When I try to make ASCII with Java it didn't show up in Console. all becames " ????? " symbol.When I check the font, there's only 'raster font' and some japanese font. When I try to add Lucida Console from the Regedit, it can't be added.Please, help me with this problem. Thanks Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 8, 2011 Report Share Posted November 8, 2011 Under Japanese mode, the backslash ('\') will show as a yen ('¥') symbol [for historical reasons]. You need to get out of Japanese mode (code page) to get rid of all the problems you are facing. Quote Link to comment Share on other sites More sharing options...
chocony Posted November 9, 2011 Author Report Share Posted November 9, 2011 could you tell me how to get out from Japanese mode?cause I already uninstalled the Japanese language long time ago Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 10, 2011 Report Share Posted November 10, 2011 The Japanese language support is not the problem; it is the code page. How to change that back depends on your Windows version. Quote Link to comment Share on other sites More sharing options...
