Boris Posted January 24, 2012 Report Share Posted January 24, 2012 That (whatever it is) only has one video output (VGA). Quote Link to comment Share on other sites More sharing options...
Boris Posted January 24, 2012 Report Share Posted January 24, 2012 Originally you saidi need to run 2 pc screens for home recordingPutting it simply,You cannot use your onboard graphics and a separate VGA card at the same time.You will need a card with 2 video outputs to run 2 PC screens.The one I linked to has 2 outputs - one DVI & one VGA. What monitors do you intend to use ? Quote Link to comment Share on other sites More sharing options...
george riley Posted January 24, 2012 Author Report Share Posted January 24, 2012 Hi Boris sorry im new to all this so i might sound a bit thick at times i will be using a couple of the old style monitors (the white ones with the large back) until i can get another Dell one then i will be using 2 Dell ones.The card is only for running 2 monitors & not for any gaming Quote Link to comment Share on other sites More sharing options...
Boris Posted January 24, 2012 Report Share Posted January 24, 2012 If you use one of these adaptershttp://www.amazon.co.uk/Cabling4Less-DVI-VGA-HD15-Adaptor/dp/B000FII810/ref=pd_bxgy_ce_text_cwith the card I linked to, you should be able to use 2 of the old CRT monitors (with VGA connections). What exactly are you meaning by "home recording" ? Quote Link to comment Share on other sites More sharing options...
george riley Posted January 25, 2012 Author Report Share Posted January 25, 2012 Hi Boris i mean recording things like guitars keyboards etc Quote Link to comment Share on other sites More sharing options...
angelsmith115 Posted January 30, 2012 Report Share Posted January 30, 2012 My son playing Starcraft and it freeze and the only way to stop it is to push the power button. Is that the problem of Graphic card?? thanks Quote Link to comment Share on other sites More sharing options...
