day23 Posted February 11, 2012 Report Share Posted February 11, 2012 My PC is not starting up correctly. It was working fine last night after I ran a virus scan using the "microsoft antivirus" program and then it told me that I had some viruses that it couldn't remove but could using a "microsoft antimalware" program. I downloaded that to my thumb drive and booted from it to run the antimalware scan. It finished this morning after running last night and then restarted. When it restarted it brought up startup repair and then doesn't boot into the os and quickly shows a blue screen and then restarts again and keeps going into startup repair but its not resolving anything. The startup repair message I get is: Problem Event Name: StartupRepairOfflineProblem signature 01: 6.1.7600.16358Problem signature 02: 6.1.7600.16358Problem signature 03: unknownProblem signature 04: 21200757Problem signature 05: Auto-failoverProblem signature 06: 10Problem signature 07: NoRootCauseOS version: 6.1.7600.2.0.0.256.1Locale ID: 1033 I can't boot into safe mode but I can get command prompt. I've tried system restore but it fails. I've done a disk check and it finds no problems. I'm really stuck with what to do next. Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted February 12, 2012 Report Share Posted February 12, 2012 I can't boot into safe mode but I can get command prompt Go to this link: http://forums.window...showtopic=48409 on the forum here, select the third video, (Advanced Windows 7 Troubleshooting 3 of 4) at the five minute mark Mike Halsey will walk you through the correct procedures to use with command prompts. If you should wish for further troubleshooting help, watch all of the videos. There are also videos by Mike at this link:http://forums.window...showtopic=48268 It doesn't get much better than having a Microsoft MVP talk you through all the stages of troubleshooting. :) It is also worth mentioning that Mike's book “Windows 7 Power Users Guide” eBook is Now FREE and downloadable here:http://www.lulu.com/...-guide/15662737 Or here: http://www.thelongcl...n7powerfree.pdf John. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 12, 2012 Report Share Posted February 12, 2012 There are no such things as "microsoft antivirus" or "microsoft antimalware"; the only anti-malware programs that Microsoft offers are WD (Windows Defender), MSE (Microsoft Security Essentials) and MRT (Malicious Software Removal Tool). If you have anything else "microsoft" installed, it is most likely fraudulent. Quote Link to comment Share on other sites More sharing options...
day23 Posted February 12, 2012 Author Report Share Posted February 12, 2012 There are no such things as "microsoft antivirus" or "microsoft antimalware"; the only anti-malware programs that Microsoft offers are WD (Windows Defender), MSE (Microsoft Security Essentials) and MRT (Malicious Software Removal Tool). If you have anything else "microsoft" installed, it is most likely fraudulent. That is what I have on my computer. I installed in from windows update so I know for a fact that it is not fraudulent software, I just didn't name it properly in my description, my apologie. I do have Microsoft Security Essentials on my PC currently, but because after the first initial scan it detected some viruses it was not able to completely remove and that I needed the addition removal tool that was provided from MSE. Quote Link to comment Share on other sites More sharing options...
