miseryguts Posted May 13, 2012 Report Share Posted May 13, 2012 I've got a pretty decent set of 2.1 earphones which I use on the go, but when I'm using them with my desktop the sound is very low & sounds particularly tinny, much more so than using them with my portable media player.Is there any particular application or Windows tweak I can use to improve things..? Thanks. Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 14, 2012 Report Share Posted May 14, 2012 I don't know if this applies to your setup but it may be due to an EU directive (or a US equivalent) the prevents personal audio devices to make any sound above a whisper level in order to protect the users ears. One of the makers of these machines has suggested using drivers intended for other countries where this ruling doesn't apply - or to revert to older drivers for the device if available. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted May 14, 2012 Report Share Posted May 14, 2012 Make sure ALL your volume settings are maxed up - that is, both the windows volume controls and the player volume controls. Also verify the Output settings of your chosen Player [which is?]Some folk use a headphone amp but I suspect you are looking for improvement without costs. You might consider this: DFX http://www.fxsound.com/dfx/ Quote Link to comment Share on other sites More sharing options...
