george riley Posted June 7, 2012 Report Share Posted June 7, 2012 I have a samsung r519 laptop but every so often the sound just goes & i have to do a basic restore to get it back any ideas please Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted June 8, 2012 Report Share Posted June 8, 2012 The next time the sound goes, rather than doing a restore, spend some time trying to diagnose where the fault may be. STEP 1. Samsung Support Centre and other solutionsFirst try to fix the problem using the Samsung Support Centre. To do so, please follow the steps below.Open All Programs > Samsung > Samsung Support Centre, or press the Fn + F7 key combination on your keyboard.Click Troubleshooting and System Diagnosis.Check the Sound Test and Start. Quote Link to comment Share on other sites More sharing options...
george riley Posted June 15, 2012 Author Report Share Posted June 15, 2012 Thanks i will try that next time :) Quote Link to comment Share on other sites More sharing options...
MrBrave Posted July 28, 2012 Report Share Posted July 28, 2012 What sound does it done? Quote Link to comment Share on other sites More sharing options...
bolton154 Posted September 8, 2012 Report Share Posted September 8, 2012 If your problem would not be solved then you can re-install your driver. Quote Link to comment Share on other sites More sharing options...
