xstjepan Posted June 24, 2012 Report Share Posted June 24, 2012 Hy!!I play farming simulator platinum edition and i have problem with game.exegame.exe has encountered a problem and needs to close.Please help. Quote Link to comment Share on other sites More sharing options...
Boris Posted June 24, 2012 Report Share Posted June 24, 2012 Have you installed the updates ?http://landwirtschaf...s2011Update.php Quote Link to comment Share on other sites More sharing options...
xstjepan Posted June 25, 2012 Author Report Share Posted June 25, 2012 yes I have installed the update but, the problem is still here? Quote Link to comment Share on other sites More sharing options...
MrBrave Posted July 7, 2012 Report Share Posted July 7, 2012 Well, try using 3Danalyzer.. Its works on me. It it still not works, there are gonna be something wrong about your Dll files. IF it still encounted error, find a patch for your game in internet and replace it! Quote Link to comment Share on other sites More sharing options...
bolton154 Posted September 19, 2012 Report Share Posted September 19, 2012 I also suggest you that try using 3Danalyzer. its really compatible . Quote Link to comment Share on other sites More sharing options...
