jaymax Posted September 22, 2012 Report Share Posted September 22, 2012 Architecture: Platform: i386 O/S: XP SP3 Several HD's, USB Devices etc. Adequate Power supplyProblem: On last launch - failed to boot Booted from another XP boot disk [small - minimal] on system OK! BUT normal BOOT launch Disk not listed Ran chkdsk /R, disk listed without contents and vol label Still NO contents listed from My Computer ! Restored MBR from stored files - No effect! Actually MBR record and listings appeared normal. Used 'Testdisk' Partitions, CHS normal and as expected, re-wrote MBR and MFT - relaunch => same results From Testdisks, files are listed (Recovery slow and tedious ; 120+ GB) seem to stall on Documents and Settings directory (extra large directory & sub directories)Any other suggestions for solution, more than welcomed !!! Quote Link to comment Share on other sites More sharing options...
Seniors707 Posted September 28, 2012 Report Share Posted September 28, 2012 Hi dear...!i m georg nick from USAi m new in this forum............!!!dear jaymax i can't understand your problem.....so i m sorry i can't help you...........!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
gasonlewis Posted November 17, 2012 Report Share Posted November 17, 2012 Try the option of windows startup repair and check. Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted November 17, 2012 Report Share Posted November 17, 2012 gasonlewis Said:Try the option of windows startup repair and check.Could you just point out to jaymax (and others trying to learn) exactly where he will find the option of Windows startup repair in Windows XP SP3 please.It is not always easy if you are not that used to finding your way around a computer.Thanks.(He may well of course have found the solution by now, as his post was almost two months ago.) Quote Link to comment Share on other sites More sharing options...
