roseytoes Posted October 29, 2012 Report Share Posted October 29, 2012 Hi thereI've been reading the posts and you guys have offered some great solutions to other posts, so I hope you might be able to help out with this problem I've been struggling with for a few weeks.Several months ago I installed Serviio on my PC and the Airplayer app on my iPad. They immediately and successfully talked to each other and I could access movies, music and photo files over my wifi network on my iPad, from my PC's hard drive. However when I last went to use it, Airplayer had been updated and the information about my PC had disappeared from its list of devices. I'm not sure what else happened, but now I can’t access my PC's media files on the iPad because the iPad can’t see the PC and vice versa.My PC doesn't recognise the iPad or iPhone as being on the same wifi network. (not that I can remember whether the PC even knew that iPad was on the same network in the past, sorry).I’m fairly proficient with computers, but my understanding of networks, routers and how devices communicate with each other is limited.After some research, I identified that the iPad (and iPhone) need a static ip if they are to connect directly to the home network (home sharing is on). I have given both these devices static ip’s within the acceptable ip range. The router now sees that the two devices are attached to it, but the computer does not.The pc operating system is windows 7, 32 bit home premium. I have AVG Internet Protection installed, so this acts as my firewall.The router is Netgear DGN 2200The server on my computer is Serviio (I have also used twonky over the last few days in an effort to resolve the problem, to no avail)The app on the iPad is AirplayerI have tried disabling the firewall but my PC's name together with a strange number came up in the iPad wifi selection (something like CHRIS PC 3029). I tried connecting to this network but the device asked me for a password. I tried all the different passwords I could think of, (router, computer, wifi password) but none of them worked. Giving up, I restarted the AVG firewall and the network disappeared.I have enabled the PC to be seen by other devices, although this seems to constantly revert to the disabled state.I hope there is someone out there who can help, as I have spent hours and hours reading forums and am struggling to resolve the issue, because I'm unclear as to what the root of the problem is.All the bestChris Quote Link to comment Share on other sites More sharing options...
bludgard Posted October 30, 2012 Report Share Posted October 30, 2012 Try going into Device Manager and uninstalling the wi-fi adaptor drivers followed by a system re-boot.Then try connecting networked devices.... Quote Link to comment Share on other sites More sharing options...
roseytoes Posted November 18, 2012 Author Report Share Posted November 18, 2012 Hi thereI tried that, but sadly nothing happened. Quote Link to comment Share on other sites More sharing options...
trantien Posted December 10, 2012 Report Share Posted December 10, 2012 I have just set up Win 7-32bit, and I have same problem ( each time start up Window, I can't access to network,to solve problem, I have to switch off Moden and then restart it. Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted December 11, 2012 Report Share Posted December 11, 2012 trantien said : I have just set up Win 7-32bit, and I have same problem Tough titty trantien. Start your own friggin thread on the subject. We is here at the moment desperately trying to help this CrinklyToe guy out my man. He has piled a whole load of crap on his machine (self inflicted) and is looking for us to sort things or wind him into a hole deeper than he is already in.Thank you for your input. Quote Link to comment Share on other sites More sharing options...
Brooklyn Posted September 2, 2013 Report Share Posted September 2, 2013 I have laptop XP and desktop Windows 7 How can i set up home network to share files and printer. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted September 2, 2013 Report Share Posted September 2, 2013 You need to set it up as a Workgroup. What particular problem are you facing? Quote Link to comment Share on other sites More sharing options...
