Yepiiz Posted January 25, 2013 Report Share Posted January 25, 2013 Hey everyone, well I've been having a problem with my USB ports, everytime I turn on my PC I have to disable and enable my USB's for them to be usable, I'm on Windows 7 64bit any help would be appreciated thanks. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 26, 2013 Report Share Posted January 26, 2013 What are the errors (error codes) of these flagged devices? Quote Link to comment Share on other sites More sharing options...
AceInfinity Posted January 30, 2013 Report Share Posted January 30, 2013 Check your event viewer, could be that it's having problems initiating on startup because of some other conflicting services or startup entries. Can't troubleshoot much without having a place to start, look for any error codes. Quote Link to comment Share on other sites More sharing options...
Yepiiz Posted February 1, 2013 Author Report Share Posted February 1, 2013 What are the errors (error codes) of these flagged devices?Check your event viewer, could be that it's having problems initiating on startup because of some other conflicting services or startup entries. Can't troubleshoot much without having a place to start, look for any error codes.This device cannot start. (Code 10)Windows did not start a related device driver. Quote Link to comment Share on other sites More sharing options...
-pops- Posted February 1, 2013 Report Share Posted February 1, 2013 Code 10 errors see http://pcsupport.about.com/od/findbyerrormessage/a/code-10-error.htm Quote Link to comment Share on other sites More sharing options...
alexalbert Posted April 24, 2013 Report Share Posted April 24, 2013 Your USB port is not installed properly try to re install the driver properly. Else you are not able to install the driver get help from windows tech supportfor solving your problem. Quote Link to comment Share on other sites More sharing options...
